Ga door naar hoofdinhoud
HP 7 1800 Battery Replacement
Wat je nodig hebt
  1. HP 7 1800 Battery Replacement, Remove the back panel: stap 1, afbeelding 1 van 2 HP 7 1800 Battery Replacement, Remove the back panel: stap 1, afbeelding 2 van 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: stap 2, afbeelding 1 van 3 HP 7 1800 Battery Replacement, Remove the battery: stap 2, afbeelding 2 van 3 HP 7 1800 Battery Replacement, Remove the battery: stap 2, afbeelding 3 van 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
TMD
765 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Brown Winter 2015 Lid van USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Leden
14 handleidingen geschreven
2 opmerkingen
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - Antwoord
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 3,322
