Inleiding
Here is a HP 310-1037 with a failed hard drive. The Hitachit 1TB hard drive is a common item to fail. The repalcement is very easy and not hidden screws or adhesive. All that is needed is a flathead screwdriver and a Phillips screwdriver.
Wat je nodig hebt
HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
Lay the PC flat on the front to gain access to the stand cover
Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
6 andere personen hebben deze handleiding voltooid.
Één opmerking
This one made me laugh - Remove two screws. Pull the drive out. Difficulty: Moderate.
LOL
