Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Remove the screws holding the plastic case by using a sharp Stanley knife, and then use a spudger to pry the rubber cushions open.
Turn the laptop around.
Open up the laptop (to remove the keyboard).
Use a spudger or iSesamo to remove the keyboard.
Slide the iSesamo around the upper side of the keyboard as shown in the pictures (you will hear clicks).
Gently lift the keyboard up.
Spot the thin ribbon cable attached to the connector (the connector has a plastic lid).
Carefully open the lid with a spudger and slide the ribbon cable out of the connector.
Close the lid again, after removing the cable, so that the cable cannot jump out.
Remove the screw circled in picture 2.
Remove the white ribbon cable from the connector.
Remove the tape over the cable and the connector.
Open up the lid with a spudger, and gently remove the ribbon cable.
Remove the two screws holding the main board to the plate (see pictures 2 and 3).
Use an IC extractor to remove the audio connector from the socket (sorry for the blurred picture).
Remove the golden antenna cable from the socket. Be very careful, and use a spudger.
Remove the screw.
The WiFi module will jump up when the screw is removed. Slide the WiFi module out.
To install the new Wifi module, slide the new WiFi module in , push it down, and put the screw back in.
Attach the antenna back in.
If the DC jack is damaged or broken in your laptop, remove the hinge instead (this is holding the DC power jack in place).
10 andere personen hebben deze handleiding voltooid.
