Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
remove the screws holding the plastic case as follows :
they are not easy to remove, i used a very sharp stanley knife and than used a spudger to pry.
now turn the laptop arround.
open up the laptop : we will remove the keyboard now.
use a spudger or isesamo to remove the keyboard. you have to slide the isesamo arround the upper side of the keyboard as shown in the picture. you will here clicks.
now gently lift up the keyboard
now you will see the very thin ribbon cable attached to a connector.
That connector has a plastic lid. gently open the lid with a spudger and slide the ribbon cable out of the connector.
be very gently with cable and connector. the lid can come loose , if this happens, it is very hard to put it back in.
after removing the cable , close the lid again, so it can't jump out.
now we can remove the final screws and cables.
remove the srew that is circled red in picture 2
remove the white ribbon cable from the connector. ( first remove the tape over the cable and connector)Same way you removed the keyboard ribbon cable. : open up the lid with spudger and remove ( gently the ribbon cable. be carefull cause the ribbon cable is pasted to the plate.
this ribbon cable is the connector from the ON/OFF switch.
here you see the motherboard / main PCB.
remove the 2 screws holding the main board to the plate.
see picture 2 and 3 for removing screws.
i'm sorry for the blurred picture...
use a IC extractor to remove the audio connector from the socket.
removing LCD connector
first remove the tape/ sticker , use a spudger.
use a IC extractor to do this. If you don't have a IC extractor , you can use 2 small flat head screwdrivers or the points of tweezers to slide the connector out of the socket. but if you can use the IC extractor.
removing the USB PCB ( on the right.)
be carefull the flat ribbon cable is pasted to the bottom plate and the ribbon cable is soldered to the PCB.
use a spudger to loose the cable from the bottom plate.
remove the golden antenna cable from his socket. be very carefull and use a spudger.
remove the screw.
remove the wifi module. it will jump up when removing the screw. slide it out.
install the new wifi module : just slide it in , push it down and put the screw back in. attach the antenna back in.
removing the main board
in this case i didn't remove the main pcb , cause than i had to remove the DC jack. but it was a very breakable connector and the wires are very thin. when you break one of them you cant charge your laptop any more.
when the dc jack is damaged or broken in your laptop, you will have to remove the hinge instead. this is holding the DC power jack in place.
10 andere personen hebben deze handleiding voltooid.
