Ga door naar hoofdinhoud
HP 24-G014 disassembly
  1. HP 24-G014 disassembly, The Stand: stap 1, afbeelding 1 van 2 HP 24-G014 disassembly, The Stand: stap 1, afbeelding 2 van 2
    • Flipping the device over here we see two Philips screws holding the stand to the computer.
    • Using a basic screw driver you will most likely find in your garage or a junk drawer we can remove these two screws.
  2. HP 24-G014 disassembly, Removing said stand: stap 2, afbeelding 1 van 1
    • After removing the two screws you can pull off the stand.
  3. HP 24-G014 disassembly, Remove the screw inside the stand slot: stap 3, afbeelding 1 van 2 HP 24-G014 disassembly, Remove the screw inside the stand slot: stap 3, afbeelding 2 van 2
    • Inside the stand slot there is an extra screw using the same screw driver remove the screw.
  4. HP 24-G014 disassembly: stap 4, afbeelding 1 van 3 HP 24-G014 disassembly: stap 4, afbeelding 2 van 3 HP 24-G014 disassembly: stap 4, afbeelding 3 van 3
    • After the screw in the stand slot is removed there are clips holding the display to the body of the system.
    • Using a prying tool such as an iFixit metal spudger or Jimmy tool you can lift the display from the body.
    • Don’t worry about accidentally striking the components as they are pretty far away except for the bottom since the speakers are there.
    • One last thing before going to the other step. I highly don’t recommend using something such as a big flat head screw driver, butter knife, or sharp knifes. But if you must you can use them.
  5. HP 24-G014 disassembly, Removing the Display from the body.: stap 5, afbeelding 1 van 1
    • After unclipping the display from the body be very gentle! As there are wires and a display connector attached to the screen.
    • To prevent damage you should open the system from bottom to top (where the HP logo is).
Conclusie
That’s it you’re done!
I am not responsible for any damages done to your device if you break it during repair.
7 andere personen hebben deze handleiding voltooid.
Hayden
296 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 173
Altijd: 9,040
