Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Flip the device over and locate the battery compartment.
Slide the battery release latch to the left until the battery is detached from its slot.
A distinguishable pop will be heard when the battery is fully released.
Locate the RAM compartment cover below the battery compartment.
Locate the Phillips head screw securing RAM compartment to plastic chassis.
Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
Use a slow, prying motion as if pulling a nail out of wood.
5 andere personen hebben deze handleiding voltooid.
