Ga door naar hoofdinhoud
HP 2000 - 2D22DX Hard Drive Replacement
Wat je nodig hebt
  1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
Conclusie
27 andere personen hebben deze handleiding voltooid.
Conor Most
2.687 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-40, Maness Spring 2014 Lid van Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 14,455
