Inleiding
If your computer is overheating, you may need to replace your CPU cooling fan. This procedure involves the removal of a few screws and disconnecting power cords. NOTE: when ordering the CPU cooling fan, you need the assembly that includes the heat sink.
Wat je nodig hebt
Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
Één andere persoon heeft deze handleiding voltooid.
