Inleiding
Disassembly down to motherboard and hard drive enclosure for the HP 17 ca1022cy
Wat je nodig hebt
To remove the bottom panel there are 9 screws (in yellow) on the back and two screws under the disk drive. The disk drive screw is in the red circle.
You'll have to remove the rubber feet to access 6 of them
Once you remove the disk drive screw (blue circle), the drive should slide out of the chassis.
Under the drive bay there are two screws to remove.
Slip a thin prying tool in the seam between the top and bottom shells and work your way around the frame.
Pull up on the connector side of the drive, then pull toward the battery, taking care not to tear it.
