Ga door naar hoofdinhoud
HP 17-bs049dx Motherboard Replacement
Wat je nodig hebt
  1. HP 17-bs049dx Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  2. HP 17-bs049dx Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  3. HP 17-bs049dx Motherboard Replacement: stap 3, afbeelding 1 van 2 HP 17-bs049dx Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  4. HP 17-bs049dx Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  5. HP 17-bs049dx Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  6. HP 17-bs049dx Motherboard Replacement: stap 6, afbeelding 1 van 2 HP 17-bs049dx Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
  7. HP 17-bs049dx Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 3 HP 17-bs049dx Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 3 HP 17-bs049dx Motherboard Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Make sure to unplug everything connected to the motherboard.
    • Be gentle with this step.
  8. HP 17-bs049dx Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
    • Once all of the screws are removed, remove the motherboard from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 815
