Inleiding
Use this guide to replace the hard drive in your HP 17-bs049dx.
Wat je nodig hebt
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Just for clarity, there are 8 screws to be removed, four that are always visible and four that are hidden under the outer ends of the rubber feet.
Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
Lift the USB port over and away from hard drive.
12 andere personen hebben deze handleiding voltooid.
2 opmerkingen
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
