Ga door naar hoofdinhoud
HP 17-bs049dx Back Panel Replacement
Wat je nodig hebt
  1. HP 17-bs049dx Back Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Back Panel Replacement, Back Panel: stap 2, afbeelding 1 van 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Back Panel Replacement: stap 4, afbeelding 1 van 2 HP 17-bs049dx Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Back Panel Replacement: stap 5, afbeelding 1 van 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Megan Paige
457 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,489
