Inleiding
This guide will help you replace and/or remove the USB ports on your device. The USB ports are essential to connecting external devices such as flash drives and wireless mouse adapters. Removal of the USB ports is quite simple once other components are removed.
Wat je nodig hebt
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Remove the one (1) 2.5mm by 3.5 mm Phillips #0 screw from the USB port plate.
