Ga door naar hoofdinhoud
HP 15-r137wm TouchSmart Audio Speakers Replacement
Wat je nodig hebt
  1. HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 3 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: stap 1, afbeelding 2 van 3 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: stap 1, afbeelding 3 van 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 3, afbeelding 1 van 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 4, afbeelding 1 van 2 HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 4, afbeelding 2 van 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: stap 5, afbeelding 1 van 2 HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 6, afbeelding 1 van 2 HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 6, afbeelding 2 van 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: stap 7, afbeelding 1 van 2 HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: stap 7, afbeelding 2 van 2
    • Remove the four (4) 2.5 mm Phillips #0 screws.
  8. HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 8, afbeelding 1 van 2 HP 15-r137wm TouchSmart Audio Speakers Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the power source from the motherboard.
    • The wires are very small and thin, so be careful when removing.
    • Lift the speakers away from the housing by sliding them out from under the motherboard.
Conclusie
Ross B Jacques
881 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S4-G4, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G4, Julie Fall 2017
UMASSD-JULIE-F17S4G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 276
