Inleiding
Is your computer running too slow and you want to replace your hard drive with an SSD or one with more RPMs? Then this is the guide for you! Replacing the hard drive in an HP 15-g071nr laptop is easier than you may think, so do not be intimidated. NOTE: Turn off laptop before starting this guide.
Wat je nodig hebt
Using your Phillips #0 screwdriver, remove all of the screws on the back case.
Bijna klaar!
Conclusie
