Ga door naar hoofdinhoud
HP 15-g029wm Upper Case Replacement
Wat je nodig hebt
  1. HP 15-g029wm Upper Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Upper Case Replacement: stap 2, afbeelding 1 van 1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Upper Case Replacement: stap 3, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 3, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 3, afbeelding 3 van 3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Upper Case Replacement: stap 4, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 4, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Upper Case Replacement, Upper Case: stap 5, afbeelding 1 van 2 HP 15-g029wm Upper Case Replacement, Upper Case: stap 5, afbeelding 2 van 2
    • Remove the following Phillips screws on the lower case:
    • Nine 5 mm
    • One 6 mm
    • This will allow the optical drive to separate from the chassis.
  6. HP 15-g029wm Upper Case Replacement: stap 6, afbeelding 1 van 1
    • Slide the optical drive directly out of its slot.
  7. HP 15-g029wm Upper Case Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
  8. HP 15-g029wm Upper Case Replacement: stap 8, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 8, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 8, afbeelding 3 van 3
    • Use an opening pick to remove the two circular rubber feet near the laptop hinges.
    • Remove both of the 8 mm Phillips screws.
    • The screws were hidden by the rubber feet.
  9. HP 15-g029wm Upper Case Replacement: stap 9, afbeelding 1 van 2 HP 15-g029wm Upper Case Replacement: stap 9, afbeelding 2 van 2
    • Use an opening pick to pry up and remove the left hinge cover.
    • Use an opening pick to pry up and remove the right hinge cover.
  10. HP 15-g029wm Upper Case Replacement: stap 10, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 10, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 10, afbeelding 3 van 3
    • Flip the device face up and open the lid.
    • Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
    • Lift the keyboard slightly.
    • There is a ribbon cable connecting the keyboard to the device on the underside. Do NOT pull it away or you risk ripping the ribbon cable and causing damage.
    • Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
    • Disconnect the keyboard ribbon cable.
    • Lift the keyboard off.
  11. HP 15-g029wm Upper Case Replacement: stap 11, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 11, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 11, afbeelding 3 van 3
    • Remove two 5 mm screws using a Phillips screwdriver.
    • Insert an opening pick in the seam between the top case and chassis.
    • Slide the opening pick around the edge of the device to separate the top case from the chassis.
    • Slightly lift the top case up and away from the chassis.
    • There is a ribbon cable connecting the top plate to the device. Handle with care, and do NOT yank on the ribbon cable to prevent damage.
  12. HP 15-g029wm Upper Case Replacement: stap 12, afbeelding 1 van 3 HP 15-g029wm Upper Case Replacement: stap 12, afbeelding 2 van 3 HP 15-g029wm Upper Case Replacement: stap 12, afbeelding 3 van 3
    • Use your fingers or an opening pick to flip up the black ZIF locking flap.
    • Disconnect the ribbon cable.
    • Lift off the top case.
Conclusie
Asmaa Kajjaj
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 104
