Ga door naar hoofdinhoud
HP 15-g029wm Screen Replacement
Wat je nodig hebt
  1. HP 15-g029wm Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Screen Replacement: stap 2, afbeelding 1 van 1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Screen Replacement: stap 3, afbeelding 1 van 3 HP 15-g029wm Screen Replacement: stap 3, afbeelding 2 van 3 HP 15-g029wm Screen Replacement: stap 3, afbeelding 3 van 3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Screen Replacement: stap 4, afbeelding 1 van 3 HP 15-g029wm Screen Replacement: stap 4, afbeelding 2 van 3 HP 15-g029wm Screen Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Open the laptop lid.
  6. HP 15-g029wm Screen Replacement: stap 6, afbeelding 1 van 2 HP 15-g029wm Screen Replacement: stap 6, afbeelding 2 van 2
    • Insert an opening pick beneath the display bezel.
    • While periodically prying, slide the opening pick around the perimeter of the bezel to sever the adhesive.
  7. HP 15-g029wm Screen Replacement: stap 7, afbeelding 1 van 1
    • Once the majority of the adhesive is severed, use an opening pick or your hands to fully remove the bezel.
  8. HP 15-g029wm Screen Replacement: stap 8, afbeelding 1 van 2 HP 15-g029wm Screen Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 4 mm screws that secure the LCD panel.
  9. HP 15-g029wm Screen Replacement: stap 9, afbeelding 1 van 1
    • Use your hands to carefully remove/lift the panel away from the device.
    • The screen is connected to the device by a cord-do NOT pull it completely away or you risk damaging the device.
  10. HP 15-g029wm Screen Replacement: stap 10, afbeelding 1 van 2 HP 15-g029wm Screen Replacement: stap 10, afbeelding 2 van 2
    • Gently peel up the tape over the display cable.
    • If there is a hinge, flip it up.
    • Remove the display cable.
Conclusie
Lawrence Bailey
205 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 78
