Ga door naar hoofdinhoud
HP 15-f004dx Keyboard Replacement
Wat je nodig hebt
  1. HP 15-f004dx Keyboard  Replacement, Battery: stap 1, afbeelding 1 van 1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Keyboard  Replacement: stap 2, afbeelding 1 van 2 HP 15-f004dx Keyboard  Replacement: stap 2, afbeelding 2 van 2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Keyboard  Replacement: stap 3, afbeelding 1 van 2 HP 15-f004dx Keyboard  Replacement: stap 3, afbeelding 2 van 2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
  4. HP 15-f004dx Keyboard  Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to delicately pry the keyboard from the laptop.
    • Run the opening tool along the top edge so a good portion is lifted from the laptop.
  5. HP 15-f004dx Keyboard  Replacement: stap 5, afbeelding 1 van 1
    • Once a large enough portion of the laptop is lifted up, use your hand to finish separating the keyboard from the laptop
  6. HP 15-f004dx Keyboard  Replacement: stap 6, afbeelding 1 van 1
    • Lift the laptop and expose the connector.
    • Lift the small black tab of the keyboard ZIF connector, and gently pull the ribbon cable free.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 550
