Ga door naar hoofdinhoud
HP 15-f004dx Battery Replacement
Wat je nodig hebt
  1. HP 15-f004dx Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Battery Replacement: stap 2, afbeelding 1 van 2 HP 15-f004dx Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Battery Replacement: stap 3, afbeelding 1 van 2 HP 15-f004dx Battery Replacement: stap 3, afbeelding 2 van 2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 303
