Ga door naar hoofdinhoud
HP 15-ef2025nr Trackpad Replacement
Wat je nodig hebt
  1. HP 15-ef2025nr Trackpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Trackpad Replacement: stap 2, afbeelding 1 van 2 HP 15-ef2025nr Trackpad Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Trackpad Replacement: stap 3, afbeelding 1 van 2 HP 15-ef2025nr Trackpad Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Trackpad Replacement: stap 4, afbeelding 1 van 2 HP 15-ef2025nr Trackpad Replacement: stap 4, afbeelding 2 van 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Trackpad Replacement: stap 5, afbeelding 1 van 3 HP 15-ef2025nr Trackpad Replacement: stap 5, afbeelding 2 van 3 HP 15-ef2025nr Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Trackpad Replacement, Trackpad: stap 6, afbeelding 1 van 2 HP 15-ef2025nr Trackpad Replacement, Trackpad: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to flip up the ZIF connector locking flap.
    • Use tweezers to disconnect the ribbon cable from the back of the track pad.
  7. HP 15-ef2025nr Trackpad Replacement: stap 7, afbeelding 1 van 3 HP 15-ef2025nr Trackpad Replacement: stap 7, afbeelding 2 van 3 HP 15-ef2025nr Trackpad Replacement: stap 7, afbeelding 3 van 3
    • Remove the six 2 mm Phillips screws securing the trackpad.
    • Remove the retaining plate from the bottom of the track pad.
    • Remove the track pad.
Conclusie
Maribella Rivera
327 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 147
