Inleiding
In this guide, we'll be going through the steps for replacing the HP 15-dy2024nr Wi-Fi card.
Issues that may cause your Wi-Fi card to be compromised:
- The card may be declining/getting old
- Damage might be caused under the cover (Water Damage or Hard Collision)
- The card may be overheated due to poor circulation (Fan potentially unresponsive)
You can confirm if the issue is your Wi-Fi card and not your service by using a well-known internet source and seeing if your internet frequently drops connections or cannot connect to any internet source.
Wat je nodig hebt
Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
Gently peel the feet from the laptop using the spudger revealing the screws underneath.
Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
Using another iFixit opening tool, slide along the seam to unhook the clips.
When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
After the clips have been released, flip the laptop over and lift the cover.
You'll find the Wi-Fi card in the top left corner of the laptop.
Use a Phillips #1 screwdriver to remove a single 2 mm screw from the Wi-Fi card.
Één andere persoon heeft deze handleiding voltooid.
