Ga door naar hoofdinhoud
HP 15-db0015dx USB/SD Card Reader Replacement
Wat je nodig hebt
  1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: stap 1, afbeelding 1 van 2 HP 15-db0015dx USB/SD Card Reader Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx USB/SD Card Reader Replacement: stap 2, afbeelding 1 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 2, afbeelding 2 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 2, afbeelding 3 van 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx USB/SD Card Reader Replacement: stap 3, afbeelding 1 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 3, afbeelding 2 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: stap 4, afbeelding 1 van 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: stap 4, afbeelding 2 van 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: stap 4, afbeelding 3 van 3
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx USB/SD Card Reader Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
  6. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: stap 6, afbeelding 1 van 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: stap 6, afbeelding 2 van 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: stap 6, afbeelding 3 van 3
    • Lift up on the connector pin that attaches the SD card reader to the motherboard
    • Gently pull the wire out
  7. HP 15-db0015dx USB/SD Card Reader Replacement: stap 7, afbeelding 1 van 2 HP 15-db0015dx USB/SD Card Reader Replacement: stap 7, afbeelding 2 van 2
    • Snake the wire underneath the battery support
    • Pull the wire out to allow the SD Card reader to be removed
  8. HP 15-db0015dx USB/SD Card Reader Replacement: stap 8, afbeelding 1 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 8, afbeelding 2 van 3 HP 15-db0015dx USB/SD Card Reader Replacement: stap 8, afbeelding 3 van 3
    • Remove the two Phillips #0 screws holding the SD Card reader in place.
    • Gently pull the SD card reader up and out of the slot.
    • A spudger may have to be used to pop the SD card reader out of place.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 449
