Inleiding
If your HP 15-da0012dx Laptop trackpad or keyboard is not inputting correct clicks, mouse movements, or keyboard inputs, follow this guide to replace the keyboard and track-pad panel.
A keyboard and track-pad should provide inputs to put information into your computer. A faulty keyboard and track-pad will allow only some inputs or even no inputs at all. Before taking apart your laptop it is smart to restart and try each the track-pad and keyboard a few times to confirm faulty hardware.
Before following this guide be sure to ground yourself by touching a metal object such as your computer case, or by using an anti-static wrist band.
Wat je nodig hebt
Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
Flip the computer over and open the screen.
Start from a corner and run the plastic opening tools along the edge of the back cover.
After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
Gently pry back the cover starting from the middle, bottom edge.
Spread the retention clips on either side of the RAM module outward until you hear a click sound.
Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
Using the Phillips #1 Screwdriver, remove the single 3.0 mm screw holding the wifi card and gently pull the wifi card away.
Use the Phillips #1 screwdriver to remove the 3mm screws holding the speakers in place.
Carefully lift the speakers out of the laptop.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
You omitted the step to remove the screen assem and also the fan
