Ga door naar hoofdinhoud
HP 15-da0012dx Screen Replacement
Wat je nodig hebt
  1. HP 15-da0012dx Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Screen Replacement: stap 2, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 2, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 2, afbeelding 3 van 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Screen Replacement: stap 3, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Screen Replacement: stap 4, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 4, afbeelding 2 van 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Screen Replacement: stap 5, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 5, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 5, afbeelding 3 van 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Screen Replacement: stap 6, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 6, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Screen Replacement: stap 7, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Screen Replacement, Screen: stap 8, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement, Screen: stap 8, afbeelding 2 van 2
    • Remove the 3 mm Phillips #0 screw securing the WLAN card in place.
    • Carefully remove the WLAN card from the motherboard.
    • Gently remove the antenna cable from the wire guides in the speaker and chassis.
    • Place WLAN card off to the side being careful not to pull on the antenna cable.
    • The antenna cable is soft and can easily be damaged.
  9. HP 15-da0012dx Screen Replacement: stap 9, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 9, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully use the metal tweezers to remove the display connection to the motherboard.
  10. HP 15-da0012dx Screen Replacement: stap 10, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 10, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 10, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to disconnect the display hinges from the base of the laptop.
  11. HP 15-da0012dx Screen Replacement: stap 11, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 11, afbeelding 2 van 2
    • Making sure to hold both the base and the screen, partially open laptop.
    • Carefully remove screen from laptop, making sure that the WLAN card is safely removed with it.
  12. HP 15-da0012dx Screen Replacement: stap 12, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 12, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 12, afbeelding 3 van 3
    • Carefully use the pry tool to separate the screen side of the hinge cover from the screen.
    • Rotate the hinge cover away from the screen to remove it from the screen.
  13. HP 15-da0012dx Screen Replacement: stap 13, afbeelding 1 van 3 HP 15-da0012dx Screen Replacement: stap 13, afbeelding 2 van 3 HP 15-da0012dx Screen Replacement: stap 13, afbeelding 3 van 3
    • Starting from the area near the hinges, gently remove the adhesive display bezel from around the screen using the iFixit opening tool.
  14. HP 15-da0012dx Screen Replacement: stap 14, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 14, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove the four 3.0 mm screws securing the screen to the top cover.
  15. HP 15-da0012dx Screen Replacement: stap 15, afbeelding 1 van 2 HP 15-da0012dx Screen Replacement: stap 15, afbeelding 2 van 2
    • Carefully lift the screen, being aware to not pull on the display cable connecting the screen to the top cover.
    • Gently remove the display cable from the back of the screen.
    • Remove the screen from the display assembly.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 3,485
