Ga door naar hoofdinhoud
HP 15-da0012dx SSD Replacement
Wat je nodig hebt
  1. HP 15-da0012dx SSD Replacement, Battery: stap 1, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: stap 2, afbeelding 1 van 3 HP 15-da0012dx SSD Replacement: stap 2, afbeelding 2 van 3 HP 15-da0012dx SSD Replacement: stap 2, afbeelding 3 van 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: stap 3, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: stap 4, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement: stap 4, afbeelding 2 van 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: stap 5, afbeelding 1 van 3 HP 15-da0012dx SSD Replacement: stap 5, afbeelding 2 van 3 HP 15-da0012dx SSD Replacement: stap 5, afbeelding 3 van 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: stap 6, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement: stap 6, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: stap 7, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement: stap 7, afbeelding 2 van 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: stap 8, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement, SSD: stap 8, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: stap 9, afbeelding 1 van 2 HP 15-da0012dx SSD Replacement: stap 9, afbeelding 2 van 2
    • Pull the SSD module away from the socket.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Xavier Hung
914 Reputatie
4 handleidingen geschreven
UC Davis, Team S20-G4, Lore Winter 2019 Lid van UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 Leden
7 handleidingen geschreven
Één opmerking
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 94
Altijd: 8,863
