Ga door naar hoofdinhoud
HP 15-da0002dx Back Cover Replacement
Wat je nodig hebt
  1. HP 15-da0002dx Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Back Cover Replacement: stap 3, afbeelding 1 van 2 HP 15-da0002dx Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Back Cover Replacement: stap 6, afbeelding 1 van 2 HP 15-da0002dx Back Cover Replacement: stap 6, afbeelding 2 van 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Back Cover Replacement: stap 7, afbeelding 1 van 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Abigail Aron
941 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 59
Altijd: 6,067
