Inleiding
This guide details how to replace the onboard speakers on an HP 15-d076nr. If your laptop is not producing noise, this may be the guide for you.
Wat je nodig hebt
Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
Locate the left and right switches at the bottom of the laptop.
Re-orient the laptop, so that the back of the laptop faces away from you.
Disconnect the ribbon cable in the bottom right corner of the laptop.
