Ga door naar hoofdinhoud
HP 15-d076nr Onboard Speakers Replacement
Wat je nodig hebt
  1. HP 15-d076nr Onboard Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Onboard Speakers Replacement: stap 2, afbeelding 1 van 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Onboard Speakers Replacement: stap 3, afbeelding 1 van 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Onboard Speakers Replacement: stap 4, afbeelding 1 van 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
  5. HP 15-d076nr Onboard Speakers Replacement, Wireless Card: stap 5, afbeelding 1 van 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
  6. HP 15-d076nr Onboard Speakers Replacement: stap 6, afbeelding 1 van 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  7. HP 15-d076nr Onboard Speakers Replacement: stap 7, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 7, afbeelding 2 van 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  8. HP 15-d076nr Onboard Speakers Replacement: stap 8, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 8, afbeelding 2 van 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
  9. HP 15-d076nr Onboard Speakers Replacement: stap 9, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 9, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 9, afbeelding 3 van 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
  10. HP 15-d076nr Onboard Speakers Replacement: stap 10, afbeelding 1 van 1
    • Slide the wireless card to the left to remove it from the socket.
  11. HP 15-d076nr Onboard Speakers Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Locate the RAM in the exposed area.
  12. HP 15-d076nr Onboard Speakers Replacement: stap 12, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 12, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 12, afbeelding 3 van 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  13. HP 15-d076nr Onboard Speakers Replacement: stap 13, afbeelding 1 van 1
    • Remove the RAM.
  14. HP 15-d076nr Onboard Speakers Replacement: stap 14, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 14, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 14, afbeelding 3 van 3
    • Locate the ribbon cables.
    • Pry up the black tabs on the connectors and disconnect both of the ribbon cables.
  15. HP 15-d076nr Onboard Speakers Replacement: stap 15, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 15, afbeelding 2 van 2
    • Locate the DVD drive screw.
    • Remove the Phillips PM2.5×6.5 screw using a Phillips #0 screwdriver.
    • Continue using a Phillips #0 screwdriver for the rest of this guide, and subsequent guides.
    • Take the screw and place it in a container so as to not lose it.
  16. HP 15-d076nr Onboard Speakers Replacement: stap 16, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 16, afbeelding 2 van 2
    • Push down the tab that is located by the DVD drive screw.
    • Take the DVD drive in one hand, and using the plastic spludger, push the tab down, and out.
  17. HP 15-d076nr Onboard Speakers Replacement: stap 17, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 17, afbeelding 2 van 2
    • Remove the fourteen Phillips PM2.5×6.0 screws, and place them in a separate container.
  18. HP 15-d076nr Onboard Speakers Replacement: stap 18, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 18, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 18, afbeelding 3 van 3
    • Flip the laptop over, and open it as if you were using it.
    • Gently, remove the laptop cover/keyboard from the laptop using the plastic spudger.
    • When you remove the cover/keyboard, the laptop will become top heavy.
  19. HP 15-d076nr Onboard Speakers Replacement: stap 19, afbeelding 1 van 1
    • Disconnect the monitor cable, using the plastic spudger, and pry it upwards.
    • Pull the cable from its routing until it is free.
  20. HP 15-d076nr Onboard Speakers Replacement: stap 20, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 20, afbeelding 2 van 2
    • Lift the black tabs, and disconnect the three ribbon cables.
    • Disconnect the red-black-white speaker cable located in the lower left corner.
  21. HP 15-d076nr Onboard Speakers Replacement: stap 21, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 21, afbeelding 2 van 2
    • Remove the three Phillips PM2.5×4.0 screws on the card reader in the bottom left corner.
    • Place the screws in a separate container.
    • Remove the card reader.
  22. HP 15-d076nr Onboard Speakers Replacement: stap 22, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 22, afbeelding 2 van 2
    • Remove the five Phillips PM2.5×5.0 screws on the motherboard.
  23. HP 15-d076nr Onboard Speakers Replacement: stap 23, afbeelding 1 van 1
    • Remove the Phillips PM2.5×5.0 screw located on the fan, in the upper right corner.
  24. HP 15-d076nr Onboard Speakers Replacement: stap 24, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 24, afbeelding 2 van 2
    • Carefully lift up the motherboard.
    • Do not completely remove the motherboard. Simply lift it. There is a black cable on the bottom of the motherboard that is anchoring it.
  25. HP 15-d076nr Onboard Speakers Replacement: stap 25, afbeelding 1 van 1
    • Locate the cable on the underside of the motherboard, in its lower right corner.
    • Carefully grip the cable, and pull downward to remove it.
  26. HP 15-d076nr Onboard Speakers Replacement: stap 26, afbeelding 1 van 1
    • Flip the motherboard over.
  27. HP 15-d076nr Onboard Speakers Replacement: stap 27, afbeelding 1 van 1
    • Locate the charge port cable connection point on the motherboard.
    • Grab the charge port cable's connector, and wiggle it to remove it.
    • Set the board off to the side.
  28. HP 15-d076nr Onboard Speakers Replacement, Onboard Speakers: stap 28, afbeelding 1 van 1
    • Disconnect the ribbon cable in the bottom right corner of the laptop.
  29. HP 15-d076nr Onboard Speakers Replacement: stap 29, afbeelding 1 van 2 HP 15-d076nr Onboard Speakers Replacement: stap 29, afbeelding 2 van 2
    • Remove the Phillips PM2.5×5.0 screw connected to the USB board.
    • Remove the USB board.
  30. HP 15-d076nr Onboard Speakers Replacement: stap 30, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 30, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 30, afbeelding 3 van 3
    • Locate the two speaker modules.
    • Remove the two Phillips PM2.5×4.0 screws on the bottom left module.
    • Remove the two Phillips PM2.5×4.0 screws on the bottom right module.
  31. HP 15-d076nr Onboard Speakers Replacement: stap 31, afbeelding 1 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 31, afbeelding 2 van 3 HP 15-d076nr Onboard Speakers Replacement: stap 31, afbeelding 3 van 3
    • Slowly lift the speakers away from the laptop body.
    • Remove the red and black cable, connecting the two speaker modules, from its routing.
    • Remove the speakers from the laptop body.
Conclusie
Amy Weed
577 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 309
