Ga door naar hoofdinhoud
HP 15-bs051od Motherboard Replacement
Wat je nodig hebt
  1. HP 15-bs051od Motherboard Replacement, RAM: stap 1, afbeelding 1 van 1
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od Motherboard Replacement: stap 2, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od Motherboard Replacement: stap 3, afbeelding 1 van 3 HP 15-bs051od Motherboard Replacement: stap 3, afbeelding 2 van 3 HP 15-bs051od Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
  4. HP 15-bs051od Motherboard Replacement: stap 4, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
  5. HP 15-bs051od Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 HP 15-bs051od Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 HP 15-bs051od Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Remove the four (4 mm) Phillips screws on the heatsink.
    • Remove the exhaust by carefully lifting it up.
  6. HP 15-bs051od Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the connecting cable of the fan and remove the fan.
  7. HP 15-bs051od Motherboard Replacement: stap 7, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pull the red, white, black, and blue cable directly out of its port.
  8. HP 15-bs051od Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Slide the left speaker out.
  9. HP 15-bs051od Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull the black and red cable connecting both speakers out of its secure fastening.
  10. HP 15-bs051od Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Pull the right speaker out by sliding from left to right.
  11. HP 15-bs051od Motherboard Replacement: stap 11, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Locate the motherboard.
    • The motherboard is the biggest blue-colored surface located inside the computer.
    • Locate the six ribbon cables.
  12. HP 15-bs051od Motherboard Replacement: stap 12, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Flip up the ZIF lock bars that keep the six ribbon cables in place.
    • Slide the rest of the ribbon cables out of their fastenings.
  13. HP 15-bs051od Motherboard Replacement: stap 13, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the four (4 mm) Phillips screws securing the motherboard.
  14. HP 15-bs051od Motherboard Replacement: stap 14, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
    • Slide the Wi-Fi card out of its port.
  15. HP 15-bs051od Motherboard Replacement: stap 15, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Unfasten the connecting cable.
  16. HP 15-bs051od Motherboard Replacement: stap 16, afbeelding 1 van 2 HP 15-bs051od Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Remove the display cable.
  17. HP 15-bs051od Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Lift up the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica Walia
589 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 6-1, Botvin Spring 2023 Lid van UMass Dartmouth, Team 6-1, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 198
