Ga door naar hoofdinhoud
HP 15-ay114cy Screen Replacement
Wat je nodig hebt
  1. HP 15-ay114cy Screen Replacement, Orient the Laptop: stap 1, afbeelding 1 van 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Screen Replacement, Push out the Battery: stap 2, afbeelding 1 van 2 HP 15-ay114cy Screen Replacement, Push out the Battery: stap 2, afbeelding 2 van 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Screen Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 HP 15-ay114cy Screen Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: stap 4, afbeelding 1 van 2 HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: stap 4, afbeelding 2 van 2
    • Insert the flat end of the plastic opening tool between the screen and plastic frame.
    • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
  5. HP 15-ay114cy Screen Replacement, Remove the Screen: stap 5, afbeelding 1 van 3 HP 15-ay114cy Screen Replacement, Remove the Screen: stap 5, afbeelding 2 van 3 HP 15-ay114cy Screen Replacement, Remove the Screen: stap 5, afbeelding 3 van 3
    • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
  6. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: stap 6, afbeelding 1 van 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: stap 6, afbeelding 2 van 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: stap 6, afbeelding 3 van 3
    • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
Conclusie
Bradley Evans
613 Reputatie
5 handleidingen geschreven
S20S3G#1 Lid van S20S3G#1
Local Repair Groups
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 311
