Ga door naar hoofdinhoud
HP 15-ay103dx Display Screen Hinges Replacement
Wat je nodig hebt
  1. HP 15-ay103dx Display Screen Hinges Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay103dx Display Screen Hinges Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay103dx Display Screen Hinges Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay103dx Display Screen Hinges Replacement: stap 4, afbeelding 1 van 1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay103dx Display Screen Hinges Replacement: stap 5, afbeelding 1 van 2 HP 15-ay103dx Display Screen Hinges Replacement: stap 5, afbeelding 2 van 2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay103dx Display Screen Hinges Replacement: stap 6, afbeelding 1 van 2 HP 15-ay103dx Display Screen Hinges Replacement: stap 6, afbeelding 2 van 2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay103dx Display Screen Hinges Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: stap 8, afbeelding 1 van 2 HP 15-ay103dx Display Screen Hinges Replacement, Display Screen Hinges: stap 8, afbeelding 2 van 2
    • Use a spudger to carefully remove the border around the display screen.
    • As long as you are slow and delicate, the border will eventually come off.
  9. HP 15-ay103dx Display Screen Hinges Replacement: stap 9, afbeelding 1 van 2 HP 15-ay103dx Display Screen Hinges Replacement: stap 9, afbeelding 2 van 2
    • Remove the two 5/16 screws in the top corners and the four in the bottom corners.
  10. HP 15-ay103dx Display Screen Hinges Replacement: stap 10, afbeelding 1 van 1
    • Carefully pull the screen from the hinges and lower it on to the table.
    • There will be wires running from the screen to the motherboard. You do not need to unplug these.
    • The hinges are made of malleable metal and are easily bent.
  11. HP 15-ay103dx Display Screen Hinges Replacement: stap 11, afbeelding 1 van 1
    • Remove the 5/16 screws securing the hinges to the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 753
