Ga door naar hoofdinhoud
HP 15-ay091ms Optical Disk Drive Replacement
Wat je nodig hebt
  1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP 15-ay091ms Optical Disk Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: stap 2, afbeelding 1 van 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: stap 2, afbeelding 2 van 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: stap 2, afbeelding 3 van 3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: stap 3, afbeelding 1 van 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: stap 3, afbeelding 2 van 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: stap 3, afbeelding 3 van 3
    • Remove the screws holding the optical drive in place using a JIS #0 screwdriver.
    • Pull the optical disk drive out of its slot.
Conclusie
Jossel Solis
173 Reputatie
1 Handleiding geschreven
Gateway, Team A-1, Gonzalez Fall 2023 Lid van Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 85
