Ga door naar hoofdinhoud
HP 15-ay052nr USB Port Replacement
Wat je nodig hebt
  1. HP 15-ay052nr USB Port Replacement, Battery: stap 1, afbeelding 1 van 1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr USB Port Replacement: stap 2, afbeelding 1 van 1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr USB Port Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr USB Port Replacement, Bottom Cover: stap 4, afbeelding 1 van 1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr USB Port Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr USB Port Replacement: stap 6, afbeelding 1 van 1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr USB Port Replacement: stap 7, afbeelding 1 van 1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr USB Port Replacement, USB Port: stap 8, afbeelding 1 van 1
    • Remove the three 3mm JIS #0 screws from the hard drive.
  9. HP 15-ay052nr USB Port Replacement: stap 9, afbeelding 1 van 1
    • Unplug the hard drive and set aside.
  10. HP 15-ay052nr USB Port Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the cable that is attached to the motherboard from the USB board.
    • The motherboard can be identified as the big blue board in the opposite side of the USB board we are replacing.
  11. HP 15-ay052nr USB Port Replacement: stap 11, afbeelding 1 van 1
    • Remove the single 3mm JIS #0 screw.
    • Once the screw is out, the USB board can be pulled out for replacement.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 356
