Ga door naar hoofdinhoud
HP 15-ay052nr Keyboard and Touchpad Replacement
Wat je nodig hebt
  1. HP 15-ay052nr Keyboard and Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Keyboard and Touchpad Replacement, Bottom Cover: stap 4, afbeelding 1 van 1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Keyboard and Touchpad Replacement, Fan: stap 8, afbeelding 1 van 1
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
  9. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
  10. HP 15-ay052nr Keyboard and Touchpad Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the three 3 mm JIS #0 screws from the hard drive.
  11. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Unplug the hard drive from the motherboard.
  12. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 12, afbeelding 1 van 1
    • Unplug display from the motherboard.
    • The connection is under a sealing sticker; peel up the sticker to unplug the connection.
  13. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 13, afbeelding 1 van 1
    • Unplug the power port from the motherboard.
  14. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 14, afbeelding 1 van 1
    • Unplug the display wire from the wireless adapter.
  15. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 15, afbeelding 1 van 1
    • Remove the single screw from the wireless card and gently remove the drive.
  16. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 16, afbeelding 1 van 1
    • Unplug the keyboard from the motherboard.
  17. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 17, afbeelding 1 van 1
    • Unplug the optical drive connection from the motherboard.
  18. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 18, afbeelding 1 van 1
    • Remove the memory chip from the motherboard by pushing the clips away from the chip.
    • The chip will pop out once the clips are pulled far enough apart.
    • This is to access the touch-pad wires.
  19. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 19, afbeelding 1 van 1
    • Unplug both (2) wires for the touch-pad from the motherboard.
  20. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 20, afbeelding 1 van 1
    • Unplug the speakers from the motherboard.
  21. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 21, afbeelding 1 van 1
    • Unplug the power button from the motherboard.
  22. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 22, afbeelding 1 van 1
    • Unscrew the four 3mm JIS #0 screws that secure the motherboard.
    • Once all the screws are removed, the motherboard can be removed by simply lifting it up.
  23. HP 15-ay052nr Keyboard and Touchpad Replacement, Keyboard and Touchpad: stap 23, afbeelding 1 van 1
    • Remove the two 3mm JIS #0 screws that secure the touchpad board.
  24. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 24, afbeelding 1 van 2 HP 15-ay052nr Keyboard and Touchpad Replacement: stap 24, afbeelding 2 van 2
    • Remove the display by unscrewing the four 3mm JIS #0 screws.
    • Remove one 2mm JIS #0 screw.
  25. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 25, afbeelding 1 van 1
    • Lift the power port from its cradle.
  26. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 26, afbeelding 1 van 1
    • Unscrew the one 3mm JIS #0 screw holding the power button board to the device.
  27. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 27, afbeelding 1 van 2 HP 15-ay052nr Keyboard and Touchpad Replacement: stap 27, afbeelding 2 van 2
    • Unscrew the two 3mm JIS #0 screws that hold the optical drive (CD-reader) connection to the device.
  28. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 28, afbeelding 1 van 2 HP 15-ay052nr Keyboard and Touchpad Replacement: stap 28, afbeelding 2 van 2
    • Remove the two (2) speakers located on the botten edge of the keyboard cover.
    • Along the edge that the touch-pad board and hard drive is located.
  29. HP 15-ay052nr Keyboard and Touchpad Replacement: stap 29, afbeelding 1 van 1
    • Make sure there is nothing else attached to the keyboard cover so all that remains is the keyboard and touch-pad.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 585
