Ga door naar hoofdinhoud
HP 15-ay014dx Optical Drive Replacement
Wat je nodig hebt
  1. HP 15-ay014dx Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Optical Drive Replacement: stap 5, afbeelding 1 van 1
    • Grip the optical drive and gently pull it out.
Conclusie
Colton King
227 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 275
