Ga door naar hoofdinhoud
HP 15-ay014dx Heat sink Replacement
Wat je nodig hebt
  1. HP 15-ay014dx Heat sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Heat sink Replacement: stap 2, afbeelding 1 van 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Heat sink Replacement: stap 3, afbeelding 1 van 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Heat sink Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Heat sink Replacement: stap 5, afbeelding 1 van 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Heat sink Replacement, Wireless Card: stap 6, afbeelding 1 van 1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Heat sink Replacement: stap 7, afbeelding 1 van 2 HP 15-ay014dx Heat sink Replacement: stap 7, afbeelding 2 van 2
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  8. HP 15-ay014dx Heat sink Replacement: stap 8, afbeelding 1 van 2 HP 15-ay014dx Heat sink Replacement: stap 8, afbeelding 2 van 2
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  9. HP 15-ay014dx Heat sink Replacement: stap 9, afbeelding 1 van 1
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  10. HP 15-ay014dx Heat sink Replacement: stap 10, afbeelding 1 van 1
    • carefully pull the card of its slot.
  11. HP 15-ay014dx Heat sink Replacement, Heat sink: stap 11, afbeelding 1 van 1
    • Remove the four screws holding the heatsink on.
  12. HP 15-ay014dx Heat sink Replacement: stap 12, afbeelding 1 van 1
    • Carefully pry the heat sink up and out of position to un-stick it from the thermal paste.
    • When reassembling, follow these steps on Aanbrengen van koelpasta underneath the heatsink.
Conclusie
Drake Scoville
533 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 431
