Ga door naar hoofdinhoud
HP 15-ay014dx Hard Drive Disk Replacement
Wat je nodig hebt
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: stap 1, afbeelding 1 van 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: stap 2, afbeelding 1 van 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: stap 3, afbeelding 1 van 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: stap 5, afbeelding 1 van 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: stap 6, afbeelding 1 van 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: stap 6, afbeelding 2 van 2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: stap 7, afbeelding 1 van 3 HP 15-ay014dx Hard Drive Disk Replacement: stap 7, afbeelding 2 van 3 HP 15-ay014dx Hard Drive Disk Replacement: stap 7, afbeelding 3 van 3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: stap 8, afbeelding 1 van 3 HP 15-ay014dx Hard Drive Disk Replacement: stap 8, afbeelding 2 van 3 HP 15-ay014dx Hard Drive Disk Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: stap 9, afbeelding 1 van 2 HP 15-ay014dx Hard Drive Disk Replacement: stap 9, afbeelding 2 van 2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: stap 10, afbeelding 1 van 1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jimmy Huynh
263 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 1,961
