Inleiding
Use this guide to replace the back cover of the HP 15-af123cl laptop computer. The back cover encloses and protects the internal components of your computer. This is at the bottom of the laptop, usually the part of the laptop that is in direct contact with a surface (such as your desk).
Before using this guide, inspect the back cover of your laptop to ensure a replacement is necessary. Some reasons for replacing the back cover could include signs of wear, such as breaks or scratches, the cover not properly fitting on your laptop, and other types of damage.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Wat je nodig hebt
Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
