Ga door naar hoofdinhoud
HP 15-af013cl Front Facing Camera Replacement
Wat je nodig hebt
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: stap 2, afbeelding 1 van 3 HP 15-af013cl Front Facing Camera Replacement: stap 2, afbeelding 2 van 3 HP 15-af013cl Front Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: stap 3, afbeelding 1 van 1
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: stap 4, afbeelding 1 van 3 HP 15-af013cl Front Facing Camera Replacement: stap 4, afbeelding 2 van 3 HP 15-af013cl Front Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: stap 6, afbeelding 1 van 2 HP 15-af013cl Front Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: stap 7, afbeelding 1 van 2 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: stap 7, afbeelding 2 van 2
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: stap 9, afbeelding 1 van 2 HP 15-af013cl Front Facing Camera Replacement: stap 9, afbeelding 2 van 2
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: stap 10, afbeelding 1 van 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the display ribbon cable from the motherboard.
Conclusie
Stephen Perreira
787 Reputatie
6 handleidingen geschreven
Cal Poly, Team S8-G6, Banghart Fall 2017 Lid van Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 408
