Ga door naar hoofdinhoud
HP 15-ac121dx Wifi Card Replacement
Wat je nodig hebt
  1. HP 15-ac121dx Wifi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Wifi Card Replacement: stap 2, afbeelding 1 van 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Wifi Card Replacement: stap 3, afbeelding 1 van 2 HP 15-ac121dx Wifi Card Replacement: stap 3, afbeelding 2 van 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Wifi Card Replacement: stap 4, afbeelding 1 van 2 HP 15-ac121dx Wifi Card Replacement: stap 4, afbeelding 2 van 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Wifi Card Replacement, Back Panel: stap 5, afbeelding 1 van 2 HP 15-ac121dx Wifi Card Replacement, Back Panel: stap 5, afbeelding 2 van 2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Wifi Card Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Wifi Card Replacement: stap 7, afbeelding 1 van 1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx Wifi Card Replacement, Wifi Card: stap 8, afbeelding 1 van 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: stap 8, afbeelding 2 van 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: stap 8, afbeelding 3 van 3
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the Wifi card.
    • Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
    • Carefully remove the Wifi card.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 392
