Ga door naar hoofdinhoud
HP 15-ac121dx CD Compartment Replacement
Wat je nodig hebt
  1. HP 15-ac121dx CD Compartment Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: stap 2, afbeelding 1 van 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: stap 3, afbeelding 1 van 2 HP 15-ac121dx CD Compartment Replacement: stap 3, afbeelding 2 van 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: stap 4, afbeelding 1 van 2 HP 15-ac121dx CD Compartment Replacement: stap 4, afbeelding 2 van 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: stap 5, afbeelding 1 van 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: stap 5, afbeelding 2 van 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: stap 5, afbeelding 3 van 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: stap 6, afbeelding 1 van 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: stap 7, afbeelding 1 van 3 HP 15-ac121dx CD Compartment Replacement: stap 7, afbeelding 2 van 3 HP 15-ac121dx CD Compartment Replacement: stap 7, afbeelding 3 van 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: stap 8, afbeelding 1 van 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: stap 8, afbeelding 2 van 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: stap 8, afbeelding 3 van 3
    • Locate the CD Compartment as shown and gently slide it out.
Conclusie
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Ashton Martin
459 Reputatie
2 handleidingen geschreven
Baylor, Team S1-G2, Johnson Spring 2018 Lid van Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 408
