Inleiding
The motherboard is the main hub for every component in a laptop. For this reason, one should always know how to access and disconnect any component from a motherboard. Removing a motherboard is also a necessary prerequisite to accessing components such as the RAM and CPU.
Wat je nodig hebt
Flip the laptop over to reveal screw locations.
Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
3 andere personen hebben deze handleiding voltooid.
