Inleiding
Before starting the steps in this guide please have the battery and CD/DVD optical drive removed.
Wat je nodig hebt
Turn the computer upside down on a level surface.
Slide the battery lock to unlock the battery.
Slide the battery release latch. The latch will click when the battery is released.
Lift the battery from the middle to remove it from the computer.
Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
Pull the CD/DVD drive outward to slide it away from the computer.
Remove two rubber feet by peeling them off.
Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
