Wat je nodig hebt
Shutdown the computer and remove the battery
Turn it right-side down, print a picture of its back cover
Use double-sided tape to stick all the screws in its right place on the printed picture
Under the ram cover there is a screw, remove it
Remove the two screws under the DVD reader
Remove the two rubber feet beside battery place
Turn the laptop right-side up and open and insert a pry tool along the top-side keyboard until release it
Release the connector to which the keyboard cable is attached, and then disconnect the keyboard cable.
Remove three screws under keyboard
Insert pry tool around the cover in which touchpad used to be until release
Release the connector to which the cable of two usb ports has been attaching
Remove the two usb ports and the speaker, and the two HDD screws then pull the HDD off
Remove metal frame in the first HDD and put it in the second
5 andere personen hebben deze handleiding voltooid.
