Ga door naar hoofdinhoud
HP 14-fq1025nr Speakers Replacement
Wat je nodig hebt
  1. HP 14-fq1025nr Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Speakers Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Speakers Replacement: stap 4, afbeelding 1 van 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Speakers Replacement, Fan: stap 6, afbeelding 1 van 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Speakers Replacement: stap 7, afbeelding 1 van 1
    Koop
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  8. HP 14-fq1025nr Speakers Replacement: stap 8, afbeelding 1 van 1
    • Remove the fan.
  9. HP 14-fq1025nr Speakers Replacement, Heat Sink: stap 9, afbeelding 1 van 1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. HP 14-fq1025nr Speakers Replacement, Speakers: stap 10, afbeelding 1 van 2 HP 14-fq1025nr Speakers Replacement, Speakers: stap 10, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
    • Two screws on the left side
    • One screw on the right side
  11. HP 14-fq1025nr Speakers Replacement: stap 11, afbeelding 1 van 1
    Koop
    • Unplug the speaker wire.
    • Use tweezers if needed.
  12. HP 14-fq1025nr Speakers Replacement: stap 12, afbeelding 1 van 1
    • Remove the speaker.
Conclusie
Nil Parra
485 Reputatie
4 handleidingen geschreven
Utah Tech University, Team 1-6, McMurrin Fall 2022 Lid van Utah Tech University, Team 1-6, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G6
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 91
