Ga door naar hoofdinhoud
HP 14-dq0051dx Wi-Fi Card Replacement
Wat je nodig hebt
  1. HP 14-dq0051dx Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 2 HP 14-dq0051dx Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 2.5mm screws from the back case.
  2. HP 14-dq0051dx Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Wi-Fi Card Replacement: stap 3, afbeelding 1 van 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Wi-Fi Card Replacement: stap 4, afbeelding 1 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 4, afbeelding 2 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 4, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the five 2.5 mm screws that secure the motherboard cover.
    • Remove the motherboard cover from the laptop.
  5. HP 14-dq0051dx Wi-Fi Card Replacement: stap 5, afbeelding 1 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 5, afbeelding 2 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the single 1mm screw that secures the WiFi card.
    • Pull the WiFi card out of its slot
    • Pull the WiFi card out slowly and gently as to not damage the card or the slot
  6. HP 14-dq0051dx Wi-Fi Card Replacement: stap 6, afbeelding 1 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 6, afbeelding 2 van 3 HP 14-dq0051dx Wi-Fi Card Replacement: stap 6, afbeelding 3 van 3
    • Pull the tab up, revealing two small wire plugs underneath
    • Gently remove the wires from their plugs
Conclusie
Akash
601 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-4, Harley Fall 2023 Lid van IUPUI, Team 2-4, Harley Fall 2023
IUPUI-HARLEY-F23S2G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 63
