Inleiding
Use this guide to replace the motherboard of your HP 14-dq0051dx laptop. The motherboard is the central part to a laptop that enables it to function as a whole. Many components are connected to the motherboard which allows data to travel within those parts.
Before beginning this replacement, turn your laptop off and unplug from the AC adapter.
Wat je nodig hebt
Turn the laptop upside down so the backside is facing up.
Remove the eight 2.5mm screws from the back case using the Phillips #1 screwdriver.
Lift the black square card covering two small cables connected to the WIFI card.
Unplug the small wires one and two with your fingers.
Use a Phillips #0 screwdriver to unscrew the single 1mm screw that secures the WIFI card.
Remove the WIFI card by gently pulling it out of its slot.
