Ga door naar hoofdinhoud
HMDX Jam Plus Battery Replacement
Wat je nodig hebt
  1. HMDX Jam Plus Battery Replacement, Battery: stap 1, afbeelding 1 van 3 HMDX Jam Plus Battery Replacement, Battery: stap 1, afbeelding 2 van 3 HMDX Jam Plus Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: stap 2, afbeelding 1 van 2 HMDX Jam Plus Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: stap 3, afbeelding 1 van 2 HMDX Jam Plus Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: stap 4, afbeelding 1 van 3 HMDX Jam Plus Battery Replacement: stap 4, afbeelding 2 van 3 HMDX Jam Plus Battery Replacement: stap 4, afbeelding 3 van 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: stap 5, afbeelding 1 van 3 HMDX Jam Plus Battery Replacement: stap 5, afbeelding 2 van 3 HMDX Jam Plus Battery Replacement: stap 5, afbeelding 3 van 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: stap 6, afbeelding 1 van 2 HMDX Jam Plus Battery Replacement: stap 6, afbeelding 2 van 2
    • Use new adhesive to secure battery back to the rest of the device.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Maxwell Erickson
587 Reputatie
4 handleidingen geschreven
Montana Tech, Team 10-3, Shirk Fall 2015 Lid van Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Leden
6 opmerkingen
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Antwoord
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Antwoord
What kind (especifications) that battery?
vecchio.farias - Antwoord
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 37
Altijd: 7,173
