Ga door naar hoofdinhoud
HMDX Chill Front Buttons Replacement
Wat je nodig hebt
  1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: stap 1, afbeelding 1 van 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: stap 1, afbeelding 2 van 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: stap 1, afbeelding 3 van 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Front Buttons Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Front Buttons Replacement: stap 3, afbeelding 1 van 2 HMDX Chill Front Buttons Replacement: stap 3, afbeelding 2 van 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Front Buttons Replacement, Front Buttons: stap 4, afbeelding 1 van 1
    • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
    • These are located underneath the rubber base, prior to removal.
  5. HMDX Chill Front Buttons Replacement: stap 5, afbeelding 1 van 2 HMDX Chill Front Buttons Replacement: stap 5, afbeelding 2 van 2
    • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
    • Push the buttons upwards, away from the base, until they come loose.
    • Use your hand to pull the linked buttons off the base.
Conclusie
Jourdan Holubasch
754 Reputatie
7 handleidingen geschreven
EWU-Giguere-S16S1G1 Lid van EWU-Giguere-S16S1G1
Community
4 Leden
Één opmerking
where can I buy new front buttons for replacement?
syanco_jim - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 424
