Ga door naar hoofdinhoud
HKC P776A Digitizer Replacement
Wat je nodig hebt
  1. HKC P776A Digitizer Replacement, Separating Digitizer and Case: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Digitizer Replacement: stap 2, afbeelding 1 van 2 HKC P776A Digitizer Replacement: stap 2, afbeelding 2 van 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: stap 3, afbeelding 1 van 2 HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: stap 3, afbeelding 2 van 2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: stap 4, afbeelding 1 van 2 HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: stap 4, afbeelding 2 van 2
    • Use the tip of the spudger to release the latches on the motherboard.
  5. HKC P776A Digitizer Replacement: stap 5, afbeelding 1 van 1
    • Remove the cable from the motherboard.
Conclusie
Spencer Pheasant
301 Reputatie
3 handleidingen geschreven
USF Tampa, Team 7-6, Remmell Winter 2015 Lid van USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 128
